[GRASS-dev] Fwd: [OSGeo-Discuss] OSGeo Google Summer of Code 2014 - ideas needed!
Hamish hamish_b at yahoo.com
Fri Feb 7 21:07:35 PST 2014
Vaclav wrote:
> This definitively sounds useful. I still don't understand why cairo
> does not solve it for d.* system. As for the GSoC idea, you should
> be more specific about relation to ps.map and which advantages it
> would have over ps to pdf conversion (which is done g.gui.psmap)
> and than something like pdf2svg tool (cleanness?).
the idea is to allow the user to import SVG graphics to use as icons and decorations within GRASS cartography, in a similar manner to how eps files can be used in ps.map already.
I didn't mean about SVG output, which as you mention the cairo driver and ps2{foo} tools (e.g. inkscape from the command line) can theoretically do.
wrt student experience & the Android + meta-data systems, I wouldn't totally rule out students who bring other talents to the table but have no previous experience with GRASS, or make it sound so hard that
a good student decides not to apply. I'm sure it will work itself out, I just don't want to put a new student in a rough
position.
cheers,
Hamish
