[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
trac at osgeo.org
Sat Feb 8 21:16:23 PST 2014
Reporter: matmar | Owner: rashadkm
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.setup | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:12 neteler]:
> The fixes attached to this ticket are not yet forward-ported to G7.
done in r58961 (with some slight modifications), note included in the
patch is a bugifx by Rashad in daemon.c: m.f.f_ma.x and m.f.f_ma.y were
reversed in older versions of the code.
it compiles ok, but I haven't checked the results.
Currently I'm sync'ing changes from devbr6 into trunk; if there are no
objections I will remove the r.li.setup Tcl/shell script/Xmonitor stuff
completely in trunk.
Since the WORKERS and server/client framework has been dropped in trunk,
it will be interesting to test if the segfaults go away there too. If they
do, the best approach for power users who can't wait would be to run
r.li.setup in G6, then symlink the ~./r.li/ user dir into the right place
for G7 and run the r.li.* modules from G7.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:30>
