[GRASS-dev] [GRASS GIS] #1214: r.li.edgedensity: segmentation fault
GRASS GIS trac at osgeo.org
Sat Feb 8 23:07:40 PST 2014
 Reporter:  neteler           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.4
Component:  Raster            |     Version:  svn-releasebranch64
 Keywords:  r.li.edgedensity  |    Platform:  Linux
      Cpu:  x86-64            |
Comment(by hamish):
 you might test in grass7 where the server/client stuff has been removed so
 r.li.daemon is simpler. If that works and 6.x doesn't, it narrows down
 where to look.
 Also, to help with reproducibility it would be good if we could all test
 with the same data and commands- see the r.li module help page examples or
 the r.li/TODO which has a number of usage examples using the standard
 sample datasets.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1214#comment:3>
