[GRASS-dev] Handling of Python scripts on MS Windows
Markus Metz
markus.metz.giswork at gmail.com
Mon Feb 10 05:41:48 PST 2014
On Mon, Feb 10, 2014 at 12:04 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 10/02/14 11:46, Markus Metz wrote:
>> On Mon, Feb 10, 2014 at 11:26 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>>>> Therefore we need
>>>>> hard-coded special treatment for shell and Python scripts in order to
>>>>> make sure that the correct interpreter is used.
>>>> Just for my understanding: When you say hard-coded special treatment for
>>>> shell scripts, are you speaking about the .bat files ?
>>> I think yes.
>> Or more generally, any mechanism explicitly using %GRASS_PYTHON%
>> script.py.
> But as far as I've seen, this might not be sufficient since this only
> indicates which Python executable to use for launching the Python script,
> but any library calls linked to that execution will involve the system-wide
> installed Python. Which is different from bash scripts, where this is not an
> issue.
GRASS Python scripts are currently executed using the system-wide
installed Python if it exists. No attempt has been made to explicitly
use GRASS_PYTHON, therefore it is not possible to say if the system's
Python would really be completely ignored.
