[GRASS-dev] wxGUI: "Search modules" tab is lacking import/export
Vaclav Petras wenzeslaus at gmail.com
Mon Feb 10 09:52:07 PST 2014
On Mon, Feb 10, 2014 at 12:33 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> (surprisingly) the "Search modules" tab does not have any content from
> the "File" menu, i.e it is lacking import/export etc.
> Is there a reason for that? It is a bit misleading...
> Hi, this is known issue [1]. The thing which is need to decide is what
will be the layout of this part of the tree. Certainly we don't want the
whole File menu in the tree. We want just the import/export separately.
Post your ideas here. Adding the actual items to the tree should be easy.
Vaclav
[1]
http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes#Whichtoolboxescouldbecreated
Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/c7c6fcb7/attachment.html>
