[GRASS-dev] wxGUI: "Search modules" tab is lacking import/export
Anna Petrášová kratochanna at gmail.com
Thu Feb 13 08:19:29 PST 2014
On Mon, Feb 10, 2014 at 12:52 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
> On Mon, Feb 10, 2014 at 12:33 PM, Markus Neteler <neteler at osgeo.org>wrote:
>> Hi,
>> (surprisingly) the "Search modules" tab does not have any content from
>> the "File" menu, i.e it is lacking import/export etc.
>> Is there a reason for that? It is a bit misleading...
>> Hi, this is known issue [1]. The thing which is need to decide is what
> will be the layout of this part of the tree. Certainly we don't want the
> whole File menu in the tree. We want just the import/export separately.
> Post your ideas here. Adding the actual items to the tree should be easy.
> we added the import/export/link toolbox and a few additional into the tree
(r59026).
Anna and Vaclav
> Vaclav
> [1]
> http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes#Whichtoolboxescouldbecreated
> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140213/4908c7d8/attachment-0001.html>
