[GRASS-dev] wxGUI: "Search modules" tab is lacking import/export
Markus Neteler
neteler at osgeo.org
Sat Feb 15 03:10:26 PST 2014
On Thu, Feb 13, 2014 at 5:19 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Mon, Feb 10, 2014 at 12:52 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> On Mon, Feb 10, 2014 at 12:33 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>>> (surprisingly) the "Search modules" tab does not have any content from
>>> the "File" menu, i.e it is lacking import/export etc.
>>> Is there a reason for that? It is a bit misleading...
>> Hi, this is known issue [1]. The thing which is need to decide is what
>> will be the layout of this part of the tree. Certainly we don't want the
>> whole File menu in the tree. We want just the import/export separately. Post
>> your ideas here. Adding the actual items to the tree should be easy.
> we added the import/export/link toolbox and a few additional into the tree
> (r59026).
Thanks a lot.
Would it be possible to make them more visible, i.e. above "Raster"? I
feel that users would expect them (also) in an own section in the
tree.
Best
Markus
> Anna and Vaclav
>> Vaclav
>> [1]
>> http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes#Whichtoolboxescouldbecreated
>>> Markus
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
