[GRASS-dev] wxGUI command line: " changed into @ while typing
Anna Petrášová
kratochanna at gmail.com
Mon Feb 10 12:25:55 PST 2014
On Mon, Feb 10, 2014 at 2:28 PM, Markus Metz
<markus.metz.giswork at gmail.com>wrote:
> On Mon, Feb 10, 2014 at 7:53 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > On Mon, Feb 10, 2014 at 1:19 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >> Hi,
> >> I noticed on Linux that while type
> >> v.extract input=lakes out=anything where=@
> >> and a map name list pops up...
> >> Is this happening to anyone else?
> > If I understand correctly, you type " character but it is changed to @
> > character. This does not happen to me with EN and CS keyboard layouts.
> The " character is changed to @ for me too on a DE keyboard layout.
Could someone test the attached diff please?
Anna
> > GRASS version: 7.0.svn
> > GRASS SVN Revision: 58850M
> > Build Date: 2014-01-03
> > GDAL/OGR: 1.10.0
> > PROJ.4: 4.8.0
> > GEOS: 3.3.8
> > SQLite: 3.7.9
> > Python: 2.7.3
> > wxPython: 2.8.12.1
> > Platform: Linux-3.2.0-58-generic-pae-i686-with-Ubuntu-12.04-precise
> >> I use
> >> GRASS SVN Revision: 58873M
> >> Build Date: 2014-01-04
> >> GDAL/OGR: 1.10.1
> >> PROJ.4: 4.8.0
> >> GEOS:
> >> SQLite: 3.8.2
> >> Python: 2.7.5
> >> wxPython: 2.8.12.0
> >> Platform: Linux-3.12.9-301.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
> >> (Un)related: on Windows this seems to work but retrieving the command
> >> from the wxGUI history by scrolling "eats" the quotes.
> >> thanks
> >> Markus
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/2a953941/attachment.html>
Index: gui/wxpython/gui_core/prompt.py
--- gui/wxpython/gui_core/prompt.py (revision 58980)
+++ gui/wxpython/gui_core/prompt.py (working copy)
@@ -175,6 +175,7 @@
# bindings
self.Bind(wx.EVT_WINDOW_DESTROY, self.OnDestroy)
+ self.Bind(wx.EVT_CHAR, self.OnChar)
self.Bind(wx.EVT_KEY_DOWN, self.OnKeyPressed)
self.Bind(wx.stc.EVT_STC_AUTOCOMP_SELECTION, self.OnItemSelected)
self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemChanged)
@@ -375,16 +376,38 @@
if len(self.autoCompList) > 0:
self.autoCompList.sort()
self.AutoCompShow(lenEntered = 0, itemList = ' '.join(self.autoCompList))
def OnKeyPressed(self, event):
- """!Key press capture for autocompletion, calltips, and command history
+ """!Key pressed capture special treatment for tabulator to show help"""
+ pos = self.GetCurrentPos()
+ if event.GetKeyCode() == wx.WXK_TAB:
+ # show GRASS command calltips (to hide press 'ESC')
+ entry = self.GetTextLeft()
+ try:
+ cmd = entry.split()[0].strip()
+ except IndexError:
+ cmd = ''
+ if cmd not in globalvar.grassCmd:
+ return
+ info = gtask.command_info(GetRealCmd(cmd))
+ self.CallTipSetBackground("#f4f4d1")
+ self.CallTipSetForeground("BLACK")
+ self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
+ else:
+ event.Skip()
+ def OnChar(self, event):
+ """!Key char capture for autocompletion, calltips, and command history
@todo event.ControlDown() for manual autocomplete
# keycodes used: "." = 46, "=" = 61, "-" = 45
# complete command after pressing '.'
- if event.GetKeyCode() == 46 and not event.ShiftDown():
+ if event.GetKeyCode() == 46:
self.autoCompList = list()
self.InsertText(pos, '.')
@@ -405,7 +428,7 @@
self.ShowList()
# complete flags after pressing '-'
- elif (event.GetKeyCode() == 45 and not event.ShiftDown()) \
+ elif (event.GetKeyCode() == 45) \
or event.GetKeyCode() == wx.WXK_NUMPAD_SUBTRACT \
or event.GetKeyCode() == wx.WXK_SUBTRACT:
@@ -425,7 +448,7 @@
self.ShowList()
# complete map or values after parameter
- elif event.GetKeyCode() == 61 and not event.ShiftDown():
+ elif event.GetKeyCode() == 61:
self.InsertText(pos, '=')
self.CharRight()
@@ -440,7 +463,7 @@
self.ShowList()
# complete mapset ('@')
- elif event.GetKeyCode() == 50 and event.ShiftDown():
+ elif event.GetKeyCode() == 64:
self.InsertText(pos, '@')
self.CharRight()
@@ -511,24 +534,6 @@
self.ShowList()
- elif event.GetKeyCode() == wx.WXK_TAB:
- # show GRASS command calltips (to hide press 'ESC')
- entry = self.GetTextLeft()
- try:
- cmd = entry.split()[0].strip()
- except IndexError:
- cmd = ''
- if cmd not in globalvar.grassCmd:
- return
- info = gtask.command_info(GetRealCmd(cmd))
- self.CallTipSetBackground("#f4f4d1")
- self.CallTipSetForeground("BLACK")
- self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
elif event.GetKeyCode() in [wx.WXK_UP, wx.WXK_DOWN] and \
not self.AutoCompActive():
# Command history using up and down
