[GRASS-dev] wxGUI command line: " changed into @ while typing
Anna Petrášová
kratochanna at gmail.com
Mon Feb 10 13:49:21 PST 2014
On Mon, Feb 10, 2014 at 3:25 PM, Anna Petrášová <kratochanna at gmail.com>wrote:
> On Mon, Feb 10, 2014 at 2:28 PM, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
>> On Mon, Feb 10, 2014 at 7:53 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > On Mon, Feb 10, 2014 at 1:19 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>> >> Hi,
>> >> I noticed on Linux that while type
>> >> v.extract input=lakes out=anything where=@
>> >> and a map name list pops up...
>> >> Is this happening to anyone else?
>> > If I understand correctly, you type " character but it is changed to @
>> > character. This does not happen to me with EN and CS keyboard layouts.
>> The " character is changed to @ for me too on a DE keyboard layout.
> Could someone test the attached diff please?
Sorry, new better diff attached.
> Anna
>> > GRASS version: 7.0.svn
>> > GRASS SVN Revision: 58850M
>> > Build Date: 2014-01-03
>> > GDAL/OGR: 1.10.0
>> > PROJ.4: 4.8.0
>> > GEOS: 3.3.8
>> > SQLite: 3.7.9
>> > Python: 2.7.3
>> > wxPython: 2.8.12.1
>> > Platform: Linux-3.2.0-58-generic-pae-i686-with-Ubuntu-12.04-precise
>> >> I use
>> >> GRASS SVN Revision: 58873M
>> >> Build Date: 2014-01-04
>> >> GDAL/OGR: 1.10.1
>> >> PROJ.4: 4.8.0
>> >> GEOS:
>> >> SQLite: 3.8.2
>> >> Python: 2.7.5
>> >> wxPython: 2.8.12.0
>> >> Platform: Linux-3.12.9-301.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
>> >> (Un)related: on Windows this seems to work but retrieving the command
>> >> from the wxGUI history by scrolling "eats" the quotes.
>> >> thanks
>> >> Markus
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/a857e045/attachment-0001.html>
Index: gui/wxpython/gui_core/prompt.py
--- gui/wxpython/gui_core/prompt.py (revision 58980)
+++ gui/wxpython/gui_core/prompt.py (working copy)
@@ -175,6 +175,7 @@
# bindings
self.Bind(wx.EVT_WINDOW_DESTROY, self.OnDestroy)
+ self.Bind(wx.EVT_CHAR, self.OnChar)
self.Bind(wx.EVT_KEY_DOWN, self.OnKeyPressed)
self.Bind(wx.stc.EVT_STC_AUTOCOMP_SELECTION, self.OnItemSelected)
self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemChanged)
@@ -375,16 +376,73 @@
if len(self.autoCompList) > 0:
self.autoCompList.sort()
self.AutoCompShow(lenEntered = 0, itemList = ' '.join(self.autoCompList))
def OnKeyPressed(self, event):
- """!Key press capture for autocompletion, calltips, and command history
+ """!Key pressed capture special treatment for tabulator to show help"""
+ pos = self.GetCurrentPos()
+ if event.GetKeyCode() == wx.WXK_TAB:
+ # show GRASS command calltips (to hide press 'ESC')
+ entry = self.GetTextLeft()
+ try:
+ cmd = entry.split()[0].strip()
+ except IndexError:
+ cmd = ''
+ if cmd not in globalvar.grassCmd:
+ return
+ info = gtask.command_info(GetRealCmd(cmd))
+ self.CallTipSetBackground("#f4f4d1")
+ self.CallTipSetForeground("BLACK")
+ self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
+ elif event.GetKeyCode() in (wx.WXK_RETURN, wx.WXK_NUMPAD_ENTER) and \
+ not self.AutoCompActive():
+ # run command on line when <return> is pressed
+ self._runCmd(self.GetCurLine()[0].strip())
+ elif event.GetKeyCode() in [wx.WXK_UP, wx.WXK_DOWN] and \
+ # Command history using up and down
+ if len(self.cmdbuffer) < 1:
+ return
+ self.DocumentEnd()
+ # move through command history list index values
+ if event.GetKeyCode() == wx.WXK_UP:
+ self.cmdindex = self.cmdindex - 1
+ if event.GetKeyCode() == wx.WXK_DOWN:
+ self.cmdindex = self.cmdindex + 1
+ if self.cmdindex < 0:
+ self.cmdindex = 0
+ if self.cmdindex > len(self.cmdbuffer) - 1:
+ self.cmdindex = len(self.cmdbuffer) - 1
+ try:
+ txt = self.cmdbuffer[self.cmdindex]
+ except KeyError:
+ txt = ''
+ # clear current line and insert command history
+ self.DelLineLeft()
+ self.DelLineRight()
+ self.InsertText(pos, txt)
+ self.LineEnd()
+ self.ShowStatusText('')
+ else:
+ event.Skip()
+ def OnChar(self, event):
+ """!Key char capture for autocompletion, calltips, and command history
@todo event.ControlDown() for manual autocomplete
# keycodes used: "." = 46, "=" = 61, "-" = 45
# complete command after pressing '.'
- if event.GetKeyCode() == 46 and not event.ShiftDown():
+ if event.GetKeyCode() == 46:
self.autoCompList = list()
self.InsertText(pos, '.')
@@ -405,7 +463,7 @@
self.ShowList()
# complete flags after pressing '-'
- elif (event.GetKeyCode() == 45 and not event.ShiftDown()) \
+ elif (event.GetKeyCode() == 45) \
or event.GetKeyCode() == wx.WXK_NUMPAD_SUBTRACT \
or event.GetKeyCode() == wx.WXK_SUBTRACT:
@@ -425,7 +483,7 @@
self.ShowList()
# complete map or values after parameter
- elif event.GetKeyCode() == 61 and not event.ShiftDown():
+ elif event.GetKeyCode() == 61:
self.InsertText(pos, '=')
self.CharRight()
@@ -440,7 +498,7 @@
self.ShowList()
# complete mapset ('@')
- elif event.GetKeyCode() == 50 and event.ShiftDown():
+ elif event.GetKeyCode() == 64:
self.InsertText(pos, '@')
self.CharRight()
@@ -511,61 +569,6 @@
self.ShowList()
- elif event.GetKeyCode() == wx.WXK_TAB:
- # show GRASS command calltips (to hide press 'ESC')
- entry = self.GetTextLeft()
- try:
- cmd = entry.split()[0].strip()
- except IndexError:
- cmd = ''
- if cmd not in globalvar.grassCmd:
- return
- info = gtask.command_info(GetRealCmd(cmd))
- self.CallTipSetBackground("#f4f4d1")
- self.CallTipSetForeground("BLACK")
- self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
- elif event.GetKeyCode() in [wx.WXK_UP, wx.WXK_DOWN] and \
- not self.AutoCompActive():
- # Command history using up and down
- if len(self.cmdbuffer) < 1:
- return
- self.DocumentEnd()
- # move through command history list index values
- if event.GetKeyCode() == wx.WXK_UP:
- self.cmdindex = self.cmdindex - 1
- if event.GetKeyCode() == wx.WXK_DOWN:
- self.cmdindex = self.cmdindex + 1
- if self.cmdindex < 0:
- self.cmdindex = 0
- if self.cmdindex > len(self.cmdbuffer) - 1:
- self.cmdindex = len(self.cmdbuffer) - 1
- try:
- txt = self.cmdbuffer[self.cmdindex]
- except KeyError:
- txt = ''
- # clear current line and insert command history
- self.DelLineLeft()
- self.DelLineRight()
- pos = self.GetCurrentPos()
- self.InsertText(pos,txt)
- self.LineEnd()
- self.ShowStatusText('')
- elif event.GetKeyCode() in (wx.WXK_RETURN, wx.WXK_NUMPAD_ENTER) and \
- self.AutoCompActive() == False:
- # run command on line when <return> is pressed
- self._runCmd(self.GetCurLine()[0].strip())
elif event.GetKeyCode() == wx.WXK_SPACE:
items = self.GetTextLeft().split()
if len(items) == 1:
