[GRASS-dev] GRASS 7: r.threshold should use "separator" option
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Tue Feb 11 11:40:28 PST 2014
Hei,
I just tried to run r.threshold in GRASS 7. Unfortunately I got an error message, so I looked into the python code and found that the module uses GRASS 6 syntax for r.stats (namely fs instead of separator) in line 41 (see: http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.threshold/r.threshold.py).
If this is changed it works fine...
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140211/2cf20ec7/attachment.html>
