[GRASS-dev] GRASS 7: r.threshold should use "separator" option
Anna Petrášová kratochanna at gmail.com
Tue Feb 11 11:47:55 PST 2014
On Tue, Feb 11, 2014 at 2:40 PM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
>  Hei,
> I just tried to run r.threshold in GRASS 7. Unfortunately I got an error
> message, so I looked into the python code and found that the module uses
> GRASS 6 syntax for r.stats (namely fs instead of separator) in  line 41
> (see:
> http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.threshold/r.threshold.py
> If this is changed it works fine...
It should be fixed. Thanks for reporting this issue!
Anna
> Cheers
> Stefan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140211/ea44165a/attachment.html>
