[GRASS-dev] r.profile limits in Windows 7
Enrico Gallo enrico.gallo at gmail.com
Wed Feb 12 00:30:29 PST 2014
Dear list,
due to strange misbehaviours, we are doing some stress tests on
r.profile under Grass 6.4 and Windows 7
Case A (less interesting, IMHO):
r.profile fails with ERROR: G_malloc when the number of pixel queried
is more than 1E6
our test: profile lenght: 300km, res=3 OK, res=2 failure ( example a
river analysis on a lidar-derived DTM)
Case B (more interesting):
r.profile fails when "profile" input is a string larger than 8100
characters (more or less)
I suppose the problem comes from a limit of cmd.exe (8191 characters)
see [0]
Please, consider that using UTM integer coordinates that means only
300 nodes, and this is not so unusual for profile analysis.
Probably, using optionally a text file as "profile" input could solve
the problem without refactoring the module...
Could be this bug solved in Grass 7?
Hope this helps
regards
enrico gallo
[0] http://support.microsoft.com/kb/830473
