[GRASS-dev] [GRASS GIS] #2195: "Query raster/vectors maps" tool fails while saving modified attribute
GRASS GIS trac at osgeo.org
Wed Feb 12 02:40:34 PST 2014
 Reporter:  artegion     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  wxGUI        |     Version:  6.4.3
 Keywords:               |    Platform:  All
      Cpu:  Unspecified  |
 If the key column is not called "cat" when saving modified attribute a
 wrong SQL command is issued
 UPDATE tablename SET .... WHERE cat=1;
 instead
 UPDATE tablename SET .... WHERE KEYNAME=1;
 [[Image(D:\ODBCtest\bug\Capture-2.jpg)]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/2195>
