[GRASS-dev] [GRASS GIS] #2195: "Query raster/vectors maps" tool fails while saving modified attribute
trac at osgeo.org
Sat Feb 15 01:57:17 PST 2014
Reporter: artegion | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: 6.4.3
Keywords: | Platform: All
Cpu: Unspecified |
Description changed by neteler:
Old description:
> If the key column is not called "cat" when saving modified attribute a
> wrong SQL command is issued
> UPDATE tablename SET .... WHERE cat=1;
> instead
> UPDATE tablename SET .... WHERE KEYNAME=1;
> [[Image(D:\ODBCtest\bug\Capture-2.jpg)]]
New description:
instead
[[Image(Capture-2.jpg)]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/2195#comment:1>
