[GRASS-dev] r.profile limits in Windows 7
Enrico Gallo
enrico.gallo at gmail.com
Fri Feb 14 05:08:59 PST 2014
2014-02-14 10:10 GMT+01:00 Hamish <hamish_b at yahoo.com>:
> Hamish wrote:
>> Once done in r.profile, this functionality will be instantly
>> available for MS Windows users (using only GUI).
> fwiw both <stdin and command line are just as available and work in
> the same way on MS Windows as in Mac and UNIX. That the MS Windows
> users are not currently getting a command line dos box from the
> default desktop icon is debatably a mis-feature (there's a long
> discussion in a trac ticket about that).
in very truth, I need r.profile in a Python script and <profile=>
option value is given using a string variable
I think "<stdin" is not an option but "coordinate_file" is OK ..
thanks
>> Note that currently when you forget to fill `profile` in GUI and
>> press Run, you will get strange behavior.
> Now it should be better, you have to leave profile= blank and also
> add "-" to the coordinate_file= option. Still possible to get stuck waiting for stdin to close, but much
> less probable.
> Hamish
