[GRASS-dev] r.profile interface changes
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 14 08:13:19 PST 2014
On 14/02/14 17:02, Vaclav Petras wrote:
> Hi,
> Hamish and I did some changes in r.profile. X monitors-related parts of
> documentation removed, standard options introduced and most notably,
> Hamish added `coordinate_file` option to enable file input and make
> clear end checkable when standard input is used.
> I'm just unsure about names `coordinate_file` and `profile`. Predefined
> name for G_OPT_M_COORDS standard option is `coordinates`, so it will be
> good if `profile` would be renamed to `coordinates`. It would also
> improve r.profile call syntax from my point of view:
> - r.profile input=... profile=
> +r.profile input=... coordinates=
> Moreover, profile is the output of r.profile, not the input. So, do you
> agree with rename of `profile` to `coordinates`?
+1
Moritz
