[GRASS-dev] [GRASS GIS] #718: r.li forgets mask/illegal filename
GRASS GIS trac at osgeo.org
Tue Feb 18 13:21:08 PST 2014
 Reporter:  kyngchaos  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.4
Component:  Raster     |     Version:  svn-releasebranch64
 Keywords:  r.li, smp  |    Platform:  All
      Cpu:  All        |
Comment(by mmetz):
 Replying to [comment:29 neteler]:
 > I retested it with current 6.4.svn:
 g.region rast=lsat7_2002_40 -p
 mkdir -p $HOME/.r.li/history/
 echo "SAMPLINGFRAME 0|0|1|1
 SAMPLEAREA 0.0|0.0|1.0|1.0" > $HOME/.r.li/history/landsat_test
 r.li.shannon map=lsat7_2002_40 conf=landsat_test out=landsat_shannon
 r.univar landsat_shannon
 ERROR: Raster map <landsat_shannon> not found
 > ... no output is produced by r.li.shannon.
 With this configuration, the output is a text file. The r.li daemon should
 have printed a corresponding message with the path to the output file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:30>
