[GRASS-dev] [GRASS GIS] #2180: r.li.shannon - r.li.pielou
trac at osgeo.org
Tue Feb 18 13:28:51 PST 2014
Reporter: matmar | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: unspecified
Keywords: r.li.shannon, r.li.pielou | Platform: Linux
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:2 mmetz]:
> Replying to [ticket:2180 matmar]:
> > r.li.shannon (and consequently r.li.pielou) returns the wrong output
when "Whole Maplayer / Select areas from the overlayed vector map" option
is used to build the configuration file.
> r.li.shannon as well as related modules (dominance, pielou, renyi,
simpson) are fixed in trunk r59072.
After more testing and bugfixing with matmar, the r.li modules seem to be
stable in G7: no more crashes, and the results are in our tests correct.
While the r.li.setup replacement in G7 is still work in progress,
r.li.setup in G6 works, but all other r.li modules in G6 must be
considered as not functional. With luck, they don't crash, and with even
more luck, the result is correct, but most likely it is not.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2180#comment:3>
