[GRASS-dev] [GRASS GIS] #2156: Parser does not honor the dash (-) means stdout convention
GRASS GIS trac at osgeo.org
Wed Feb 19 17:42:00 PST 2014
 Reporter:  wenzeslaus                    |       Owner:  grass-dev@…
     Type:  defect                        |      Status:  new
 Priority:  trivial                       |   Milestone:  7.0.0
Component:  Parser                        |     Version:  svn-trunk
 Keywords:  stdout, r.colors.out, m.proj  |    Platform:  Unspecified
      Cpu:  Unspecified                   |
Comment(by annakrat):
 Replying to [comment:2 wenzeslaus]:
 > Maybe, GUI caused it. I'm almost sure that it was done by GRASS. It
 happened several times at different computers (and the file is always in
 the place where I start GRASS session, so current directory). The main
 reason why I reported this issue is that if you encounter the first non-
 reported issue and then after some time this one, it takes some time to
 understand.
 I found out that m.proj dialog caused this. It has a dash as a default
 parameter so when I entered text in the 'or enter values interactively' it
 didn't automatically create a temporary file but instead created file with
 name -. I fixed this case (r59097) so probably this problem will not
 appear again. The ticket is still valid although even less important.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2156#comment:3>
