[GRASS-dev] GSoC ideas - vector legend, medial axis
Markus Metz
markus.metz.giswork at gmail.com
Thu Feb 20 13:06:24 PST 2014
On Thu, Feb 20, 2014 at 9:08 AM, Tereza Fiedlerová
<tfiedlerova at gmail.com> wrote:
> Hello,
> I'm thinking about participating in GSoC this year, if I find some
> interesting topic. I went through GRASS GSoC ideas. The two most interesting
> for me are Vector legend and Extracting the medial axis of polygon. I would
> appreciate if anyone can give me more information to these topics.
> The first one is maybe described enough and I just need to study that more
> to understand it better, but still anything more regarding that would be
> appreciated.
> The medial axis is not really clear to me. I know what is medial axis, but I
> would like to know more about desired results. How it should be integrated
> to GRASS (some new module?). Is it necessary to write it in C (why not
> python)? Should the result algorithm extract the exact medial axis or the
> approximation? ...
A good approximation would be fine. It would be necessary to write in
C for efficiency reasons and because C library functions need to be
heavily used. Additionally, search structures like balanced binary
search trees and min heaps are needed which are already implemented in
GRASS as C code. I have already written 2 different C modules trying
to extract the medial axis, both are incredibly complex and none of
them works properly. I am familiar with GRASS, C, and Python and like
to use the easiest approach. In this case I am pretty sure that the
easiest and most appropriate approach is using C, not Python.
Therefore I would recommend a good knowledge of C and some knowledge
of the GRASS C API for this project.
Markus M
> And one more question. Is any of these topics suitable for me if I am not
> experienced in GRASS at all?
> Thank you
> Tereza Fiedlerová
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
