[GRASS-dev] wxGUI digitizer broken in all branches
Vincent Bain
bain at toraval.fr
Tue Feb 25 13:31:03 PST 2014
Hello Markus,
here on a fresh 6.4 svn build (59140) it works.
Did you check if your vector map is 3d ?
For the same reason I've never been able to edit features with non-null
elevation in wxGUI digitizer.
Yours,
Vincent.
Le mardi 25 février 2014 à 22:11 +0100, Markus Metz a écrit :
> In the wxGUI digitizer, I can no longer select vector features. Since
> I can not select vector features, I can't do anything, no move,
> delete, edit, etc.
> Unfortunately this applies to all branches.
> Markus M
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
