[GRASS-dev] wxGUI digitizer broken in all branches
Markus Metz
markus.metz.giswork at gmail.com
Tue Feb 25 13:52:43 PST 2014
On Tue, Feb 25, 2014 at 10:31 PM, Vincent Bain <bain at toraval.fr> wrote:
> Hello Markus,
> here on a fresh 6.4 svn build (59140) it works.
> Did you check if your vector map is 3d ?
> For the same reason I've never been able to edit features with non-null
> elevation in wxGUI digitizer.
Thanks! That was it!
> Yours,
> Vincent.
> Le mardi 25 février 2014 à 22:11 +0100, Markus Metz a écrit :
>> In the wxGUI digitizer, I can no longer select vector features. Since
>> I can not select vector features, I can't do anything, no move,
>> delete, edit, etc.
>> Unfortunately this applies to all branches.
>> Markus M
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
