Hi, 2014-02-25 22:52 GMT+01:00 Markus Metz <markus.metz.giswork at gmail.com>: >> Did you check if your vector map is 3d ? >> For the same reason I've never been able to edit features with non-null >> elevation in wxGUI digitizer. > > Thanks! That was it! I will take a look on this issue, Martin
