[GRASS-dev] [GRASS GIS] #2150: Cannot call Python scripts from Python on MS Windows
trac at osgeo.org
Thu Jan 2 00:47:26 PST 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Python | Version: svn-releasebranch64
Keywords: packaging, MAXREPEAT, scripts | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by hellik):
please see also ticket http://trac.osgeo.org/grass/ticket/2138 for some
improvements related to addon python script in wingrass6. Hamis did some
work in wingrass6dev, IMHO we are near a working solution for addon
scripts, some issues are open.
Replying to [ticket:2150 wenzeslaus]:
> On MS Windows, GRASS does not ensure that its Python executable is used
when calling Python script from Python script. This is a problem when some
other software installed some other version of Python system-wide.
> Currently, GRASS is using Python 2.7.4 and when the 3rd party software
installs Python 2.7.3 this one (EXE and DDL) is used but with 2.7.4
packages which causes the famous `MAXREPEAT` error.
> It is not clear who to blame for the issue (GRASS, MS Windows way of
calling programs or 3rd party software installing old Python) but it seems
that it is GRASS who has to fix the problem.
> The issue may appear when:
> * Python script calls Python script
please see ticket mentioned above, Python script calls Python script is
working by Hamish's hack
> * wxGUI calls Python scripts (in its own way or using same mechanism as
GRASS Python scripts; example is GUI command console)
> * C module calling Python scripts (not included in the ticket title, no
issue reported so far, probably not tested; case of g.gui and parser
starting generated module forms/dialogs)
> The issue was previously discussed in:
> * [http://lists.osgeo.org/pipermail/grass-dev/2013-April/063285.html
new osgeo4w-python and winGrass643RC3-standalone: error in GUI startup]
([http://osgeo-org.1560.x6.nabble.com/new-osgeo4w-python-and-
winGrass643RC3-standalone-error-in-GUI-startup-td5048496.html nabble])
> * [http://lists.osgeo.org/pipermail/grass-dev/2013-July/065197.html
Python handling in winGRASS7] ([http://osgeo-org.1560.x6.nabble.com/Re-
GRASS-GIS-7-tech-preview-release-preparations-tp5066002p5069419.html
nabble])
> * [http://lists.osgeo.org/pipermail/grass-dev/2013-October/065896.html
Handling of Python scripts on MS Windows] ([http://osgeo-
org.1560.x6.nabble.com/Handling-of-Python-scripts-on-MS-Windows-
td5081335.html nabble])
> * #1941 wxGUI fails with Japanese locale --> mixed Python installs on
Windows
> * #2015 Missing file association dialog pops up all the time
> * #2039 Startup Error
> Provided patches:
> * putting DLLs to `bin` not `lib` in r57639 + r57646 and for G6 r57694
(applied and works: GRASS GUI starts but calling Python scripts does not
work)
> * ensuring the right Python executable manually in r57910; the non-GUI
part reverted in r57911 as a confusing workaround hiding the problem
> It is possible to test using `v.db.univar` module which calls
`db.univar` module (both are Python scripts).
> The issue is not so big for G6
IMHO it's also important for G6 as there are a lot of python addon
scripts.
>but it is very serious for G7 where a lot of modules are Python scripts.
But it is even a bigger problem for addons and user scripts which are
expected to be written mainly in Python using a lot of existing GRASS
modules.
> The issue is discussed at many places, let's continue the discussion
here only.
please also add important points in ticket/2138.
thanks
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/2150#comment:3>
