[GRASS-dev] Testing sample fire simulation data in GRASS 7
Markus Neteler neteler at osgeo.org
Thu Jan 2 06:13:50 PST 2014
On Thu, Jan 2, 2014 at 12:25 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> I wanted to test sample fire simulation data
> (http://grass.osgeo.org/download/sample-data/) in GRASS 7. I used the
> provided script and tried one command after each other (you cannot use the
> whole script because of r.spread X mon connection).
> However, the r.ros command is working only partially for me:
> GRASS 7.0.svn (fire_demolocation):~/... > r.ros -s model=fuel_model
> moisture_1h=1hour_moisture  moisture_live=live_moisture velocity=wind_speed
> direction=wind_direction slope=slope aspect=aspect elevation=elevation
> output=my_ros
>  100%
> ERROR: Invalid descriptor: 11
If you run it without -s, it works:
GRASS 7.0.svn (fire_demolocation):~/grassdata/fire_demolocation >
g.remove --q rast=my_ros.max,my_ros.base,my_ros.maxdir,my_ros.spotdist,my_spread,my_spread.x,my_spread.y,my_path
WARNING: ...
r.ros model=fuel_model moisture_1h=1hour_moisture
output=my_ros
 100%
r.ros complete. Raster maps <my_ros.base>, <my_ros.max> and <my_ros.maxdir>
created.
So the issue in in the -s code.
Markus
