[GRASS-dev] r.diversity.py for GRASS 7
Paulo van Breugel p.vanbreugel at gmail.com
Mon Jan 6 02:13:17 PST 2014
Hi Markus,
Thanks, I was able to install it. Running it gave me the error :
  File "/home/paulo/.grass7/addons/scripts/r.diversity",
line 284, in <module>
    sys.exit(main())
line 139, in main
    checkAlpha(methods,alpha_value)
UnboundLocalError: local variable 'alpha_value' referenced
before assignment
After filling in an alpha value (1) it runs but I get the next error
message (but the alpha value should be optional, right?):
ERROR: Cannot find configuration file
</home/paulo/.grass7/r.li/conf_diversity_3.0>
[1.0]
All works are terminated
Indeed, in the given folder there is not such conf file.
Cheers,
Paulo
On Mon 06 Jan 2014 12:57:28 AM CET, Markus Neteler wrote:
> Hi Paulo,
> (cc Luca)
> On Sun, Jan 5, 2014 at 10:50 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> Hi,
>> I just tried to install the r.diversity addon in GRASS 7, but it doesn't
>> seem to work. Are there any plans to port this in the near future to GRASS
>> 7?  I had a look myself, but my Python skills are too limited.
> Done in r58619 (easy since it was already written in Python) and r58621.
> You may try with g.extension to install and use it but I think it
> needs a bit more finetuning (I didn't get the examples running yet,
> but it will be rather easy for a Python programmer).
> Markus
