[GRASS-dev] v.clean problem with rmarea (ERROR: Area merging failed)
Markus Metz markus.metz.giswork at gmail.com
Wed Jan 8 12:50:45 PST 2014
On Tue, Dec 31, 2013 at 5:23 AM, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> (SVN G7)
> it does work with thres inferior to 600, but not above...
> v.clean input=vnir4567_seg_0 output=vnir4567_seg_0_no_small_areas type=area
> tool=rmarea thres=10000.00 --overwrite
> Tool: Threshold
> Remove small areas: 10000
> WARNING: Vector map <vnir4567_seg_0_no_small_areas> already exists and will
> be overwritten
> Copying features...
> Rebuilding parts of topology...
> Building topology for vector map
> <vnir4567_seg_0_no_small_areas at PERMANENT>...
> Registering primitives...
> 19070 primitives registered
> 187624 vertices registered
> Building areas...
> 5344 areas built
> 251 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 8636
> Number of primitives: 19070
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 13729
> Number of centroids: 5341
> Number of areas: 5344
> Number of isles: 251
> Tool: Remove small areas
Should be fixed in r58647.
Markus M
