[GRASS-dev] [GRASS GIS] #1219: Integrate the IGNF register and the shift grid RGF93-NTF in grass
trac at osgeo.org
Sun Jan 12 23:49:17 PST 2014
Reporter: lemaitret | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.4
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: IGNF register shift grid NTF RGF93 | Platform: All
Cpu: All |
Comment(by vincent):
Replying to [comment:4 neteler]:
> I don't know how to solved this issue. Just add more files to GRASS?
We evoked this issue here for the last time :
http://lists.osgeo.org/pipermail/grass-user/2013-August/068804.html
You mentioned a possible new mechanism for grass to use these files
(registers and grids) directly from proj directories (/usr/share/proj)
instead of copies.
In the case of french projections, proj4 integrated IGNF and ntf_r93.gsb
since version 4.6 or so.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1219#comment:5>
