[GRASS-dev] GRASS 7 r.what introduces duplicates
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Mon Jan 20 15:42:44 PST 2014
Hi Luca,
Thanks for your reply. I investigated a bit more and suspect the problem arises from the "points" option which I used....
When I extract the coordinates from my vector map and feed them as a list to the "coordinates" option I get the correct number of lines from r.what (like you did). But when I use the same file directly in the points option the last line is duplicated (using r 58048 btw.).
Cheers
Stefan
-----Original Message-----
From: Luca Delucchi [mailto:lucadeluge at gmail.com]
Sent: 21. januar 2014 00:10
To: Blumentrath, Stefan
Cc: GRASS developers list (grass-dev at lists.osgeo.org)
Subject: Re: [GRASS-dev] GRASS 7 r.what introduces duplicates
On 20 January 2014 19:13, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> Hi,
> When I used r.what in GRASS 7 on Ubuntu 12.04 LTS (64bit) it
> introduced duplicates (in my two cases it duplicated the last line of output).
> Can it be a problem of my installation or shall I file a ticket?
I think it is your problem, I have no problem with GRASS7 r58751.
nc_spm_08 dataset
GRASS 7.0.svn (nc_spm_08):~ > r.what map=elevation coo=631000,228400
631000|228400||137.0444
> Cheers
> Stefan
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
