[GRASS-dev] GRASS 7 r.what introduces duplicates
Luca Delucchi
lucadeluge at gmail.com
Mon Jan 20 15:50:55 PST 2014
On 21 January 2014 00:42, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi Luca,
Hi Stefan,
> Thanks for your reply. I investigated a bit more and suspect the problem arises from the "points" option which I used....
> When I extract the coordinates from my vector map and feed them as a list to the "coordinates" option I get the correct number of lines from r.what (like you did). But when I use the same file directly in the points option the last line is duplicated (using r 58048 btw.).
Yes you are right, please open a ticket...
> Cheers
> Stefan
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
