[GRASS-dev] GRASS 7 r.what introduces duplicates
Markus Metz
markus.metz.giswork at gmail.com
Mon Jan 20 23:39:38 PST 2014
On Tue, Jan 21, 2014 at 12:50 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 21 January 2014 00:42, Blumentrath, Stefan
> <Stefan.Blumentrath at nina.no> wrote:
>> Hi Luca,
> Hi Stefan,
>> Thanks for your reply. I investigated a bit more and suspect the problem arises from the "points" option which I used....
>> When I extract the coordinates from my vector map and feed them as a list to the "coordinates" option I get the correct number of lines from r.what (like you did). But when I use the same file directly in the points option the last line is duplicated (using r 58048 btw.).
> Yes you are right, please open a ticket...
Fixed in trunk r58752.
Markus M
>> Cheers
>> Stefan
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
