[GRASS-dev] Handling of Python scripts on MS Windows
Markus Metz markus.metz.giswork at gmail.com
Tue Jan 28 11:25:34 PST 2014
On Tue, Jan 28, 2014 at 5:13 PM, Pietro <peter.zamb at gmail.com> wrote:
> On Tue, Jan 28, 2014 at 3:52 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 28/01/14 16:07, Vaclav Petras wrote:
>>> The current problem is that there
>>> is a incompatibility between Python 2.7.3 and 2.7.4; some import fails
>>> because older system Python library (dll)  does not contain MAXREPEAT
>>> variable. (To be honest, now I'm not sure how (dll) library is involved
>>> in this. I remember that even our python.exe was using dll from system
>>> Python...)
>> I think this is the main issue: AFAIU, unless we completely isolate the
>> GRASS Python environment from the outside, mixes such as can potentially
>> happen.
>> virtualenv might be a solution to this, but I don't know it enough.
> I'm using virtualenv daily to isolate GRASS on my system (linux), but
> still I'm not sure if could be the solution for windows users. I guess
> could be a solution if we create a setup.py file using setuptools [0]
> transforming GRASS into a normal python package (like: numpy, gdal,
> proj4, etc.).
> In this way all the Mac/Linux/windows users should be able to install
> GRASS and all its dependencies with:
> $ easy_install grass
> or using pip
> $ pip install grass
I am afraid this does not work if there is no system-wide python
installation. Moreover, how would easy_install and pip know that they
should use GRASS_PYTHON? I mean,
$ pip install grass
could then only work if GRASS with GRASS_PYTHON is already installed?
Markus M
> But I've never used setuptools so I don't have the knowledge to set
> and configure a setup.py file for such complex project like GRASS.
> Pietro
> [0] https://pypi.python.org/pypi/setuptools
