[GRASS-dev] GSoC idea: Testing framework
Vaclav Petras
wenzeslaus at gmail.com
Fri Jan 31 07:52:27 PST 2014
On Fri, Jan 31, 2014 at 2:32 AM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> Hi Vaclav,
> It might be interesting to look at CTest and dashboard from cmake project
> http://www.cmake.org/cmake/help/v2.8.8/ctest.html
> http://www.cdash.org/
> Thanks, I haven't noted this there but yes, some server-side running of
tests must be considered and my idea so far is that the framework will not
try to solve this, it will just be ready to be used there.
> On Fri, Jan 31, 2014 at 7:05 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> Hi Vaclav,
>> I would be interested to help for the imagery modules,
>> Good luck !
>> Yann
>> On 31 January 2014 09:23, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>> Hi all,
>>> I would like to apply to GSoC this year with the idea of testing
>>> framework for GRASS. I probably don't have to explain the need for it.
>>> Sören suggested that he would be my mentor in case my application is
>>> successful. I hope also that I will get the feedback from all developers,
>>> now or in the future, because it is crucial that GRASS developers will
>>> actually use this framework.
>>> I described the idea shortly on Trac GSoC 2014 wiki page. I plan to
>>> include more notes on separate page in next weeks but the basic idea should
>>> be clear. Some discussion is also in #2105. Perhaps, the most innovative
>>> idea is that different types of tests should be supported (e.g. Python
>>> doctest and shell scripts), although it would be always driven form Python.
>>> For example, it seems that doctest is very convenient for modules which has
>>> standard input and output (see recent doctest for r.category module).
>>> Best regards,
>>> Vaclav
>>> http://trac.osgeo.org/grass/wiki/GSoC/2014#TestingframeworkforGRASSGIS
>>> http://trac.osgeo.org/grass/ticket/2105
>>> http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.category/test_rcategory_doctest.txt
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140131/376afd62/attachment.html>
