[GRASS-dev] Installing MS DLLs failed because of 404
Vaclav Petras wenzeslaus at gmail.com
Tue Jul 1 14:26:32 PDT 2014
On Tue, Jul 1, 2014 at 5:03 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> >The guide is there but I don't want to see the user struggling with
> unpacking tar.bz2 on MS Window. zip or 7z would be helpful.
> 7zip can unzip and untar tar.bz2. so if you have installed 7zip, you can do
> this.
> Excellent. I was not aware of that. Added to the wiki.
http://grasswiki.osgeo.org/wiki/WinGRASS_errors#The_GRASS_GIS_.28winGRASS.29_exits_immediately_after_I_start_it.21
> >The package is >12 MB, so size is the issue?
> I would say manpower; there are 1-2 persons maintaining OSGeo4W base
> packages.
> I can understand that. Since 7-Zip (which is open source) can handle it, I
don't see any problem with tar.bz2 (especially when it is now noted in the
guide).
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/Installing-MS-DLLs-failed-because-of-404-tp5149036p5149095.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140701/b98c4bd5/attachment.html>
