[GRASS-dev] Installing MS DLLs failed because of 404
Helmut Kudrnovsky hellik at web.de
Tue Jul 1 14:03:52 PDT 2014
>The guide is there but I don't want to see the user struggling with
unpacking tar.bz2 on MS Window. zip or 7z would be helpful.
7zip can unzip and untar tar.bz2. so if you have installed 7zip, you can do
this.
>The package is >12 MB, so size is the issue?
I would say manpower; there are 1-2 persons maintaining OSGeo4W base
packages.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Installing-MS-DLLs-failed-because-of-404-tp5149036p5149095.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
