[GRASS-dev] [GRASS GIS] #1938: r.fillnulls: per hole filling speed-up
trac at osgeo.org
Tue Jul 1 15:48:27 PDT 2014
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: reopened
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: r.fillnulls
Platform: All | Cpu: All
Changes (by sbl):
* status: closed => reopened
* component: Shell Scripts => Python
* platform: Unspecified => All
* milestone: 7.0.0 => 7.1.0
* resolution: fixed =>
* cpu: Unspecified => All
Comment:
Please find attached another proposal for speed-up of rst-interpolation by
hole.
In the diff, there are two sections which can probably be removed in
addition:
1) The new r.clump version should account for NoData, so the following
r.mapcalc operation can be removed (could not test it since I work with an
older version).
2) I was unsure if r.patch has a limit regarding the number of open maps,
if not than block-wise application of r.patch can be removed too...
Maybe better to use bilinear or bicubic interpolation as default as it is
significant faster (and simpler) than rst?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1938#comment:2>
