[GRASS-dev] compiling grass 7 - can't find gdal (but it is there)
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Jul 2 11:41:45 PDT 2014
Hi, I am trying to compile grass7 (revision 61123) on Ubuntu 14.04, but the
configuring fails with:
checking whether to use GDAL... yes
checking for gdal-config... /usr/bin/gdal/bin/gdal-config
configure: error: *** Unable to locate GDAL library.
The path /usr/bin/gdal/bin/gdal-config is correct. In addition, I could
configure and build an earlier grass revision without problems (this is
actually the first time in a very long time the process already fails at
configure). Since then nothing has changed in respect to gdal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140702/b518380b/attachment.html>
