[GRASS-dev] compiling grass 7 - can't find gdal (but it is there)
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Jul 4 03:03:16 PDT 2014
OK, this seems to be solved with the latest update.. thanks :-)
On Wed, Jul 2, 2014 at 8:41 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi, I am trying to compile grass7 (revision 61123) on Ubuntu 14.04, but
> the configuring fails with:
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/bin/gdal/bin/gdal-config
> configure: error: *** Unable to locate GDAL library.
> The path /usr/bin/gdal/bin/gdal-config is correct. In addition, I could
> configure and build an earlier grass revision without problems (this is
> actually the first time in a very long time the process already fails at
> configure). Since then nothing has changed in respect to gdal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140704/b0b05512/attachment.html>
