[GRASS-dev] r.mapcalc - expression line to long
Helmut Kudrnovsky
hellik at web.de
Wed Jul 2 23:00:33 PDT 2014
Glynn Clements wrote
> Helmut Kudrnovsky wrote:
>> by running the python script, a r.mapcalc-error pops up that the
>> expression
>> line is to long.
> Can you provide the exact message?
> There shouldn't be any practial limitation on the length of an
> expression in r60662 and later.
> [Previously, there may have been OS-imposed limitations on the length
> of a command line, but r60662 changed grass.script.mapcalc() to pass
> the expression via stdin rather than the command line.]
> Glynn Clements
"Step 3: Calculation of elevation percentile PCTL3
Die Befehlszeile ist zu lang.
ERROR: An error occurred while running r.mapcalc"
translation:
"The command line is too long."
it's this script
http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-mapcalc-expression-line-to-long-tp5149281p5149370.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
