[GRASS-dev] r.mapcalc - expression line to long
Helmut Kudrnovsky
hellik at web.de
Wed Jul 2 23:05:42 PDT 2014
Helmut Kudrnovsky wrote
> Glynn Clements wrote
>> Helmut Kudrnovsky wrote:
>> There shouldn't be any practial limitation on the length of an
>> expression in r60662 and later.
>> [Previously, there may have been OS-imposed limitations on the length
>> of a command line, but r60662 changed grass.script.mapcalc() to pass
>> the expression via stdin rather than the command line.]
>> Glynn Clements
now tested with
GRASS version: 7.0.0svn
GRASS SVN Revision: 61115
Build Date: 2014-07-02
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
could it be that r60662 is only in trunk and not in 7.0.0svn?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-mapcalc-expression-line-to-long-tp5149281p5149371.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
