[GRASS-dev] [GRASS GIS] #2356: r.stream.basisns uses more memory than given in memory option
GRASS GIS trac at osgeo.org
Fri Jul 4 01:24:48 PDT 2014
 Reporter:  sbl                      |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  7.1.0
Component:  Addons                   |     Version:  svn-trunk
 Keywords:  r.stream.basins, memory  |    Platform:  Linux
      Cpu:  x86-64                   |
Changes (by hamish):
  * keywords:  r.stream.basisns, memory => r.stream.basins, memory
  * component:  Raster => Addons
Comment:
 were the input maps CELL, FCELL or DCELL?
 fwiw here's the code,
  opt_swapsize->description = _("Maximum memory used in memory swap mode
 (MB)");
  opt_swapsize->answer = "300";
  number_of_segs = (int)atof(opt_swapsize->answer);
  number_of_segs = number_of_segs < 32 ? (int)(32 / 0.12) : number_of_segs
 / 0.12;
 if the stream_rast= option is used then two ram_create_map()s happen.
 Likely the above number_of_segs isn't taking that into account.
 did it work ok when you halved the memory= option?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2356#comment:1>
