[GRASS-dev] [GRASS GIS] #2356: r.stream.basisns uses more memory than given in memory option
trac at osgeo.org
Fri Jul 4 01:26:59 PDT 2014
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Addons | Version: svn-trunk
Keywords: r.stream.basins, memory | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
I wrote:
> if the stream_rast= option is used then two ram_create_map()s happen.
sorry, two seg_create_map() happen without stream_rast=, three if with it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2356#comment:2>
