[GRASS-dev] using rand(x,y) in r.mapcalc (grass7)
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Jul 4 06:01:04 PDT 2014
On Thu, Jul 3, 2014 at 9:39 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Just a quick additional question, how to set this GRASS_RND_SEED from
> within a python script (I want to add the option to set the seed with a
> seed parameter in my script, as suggested in the previous email).
Concerning the question above, I found out how to do so. I used it in my
r.random.weight script (in grass 7 addons svn). This script uses the rand()
function in r.mapcalc. But rather than using the same seed (1), there is
the option to set the seed, while as default the a time-dependent seed is
set. I am sure there are better ways to do this, but it works.
> On Thu, Jul 3, 2014 at 8:55 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> On 03-07-14 03:43, Vaclav Petras wrote:
>> On Wed, Jul 2, 2014 at 8:15 PM, Glynn Clements <glynn at gclements.plus.com>
>> wrote:
>>> > Shouldn't the seed not be generated on e.g, OS time,
>>> > which would ensure that each run would give a different result?
>>> No. The reason is to provide reproducibility. Anyone running the same
>>> command with the same data should obtain the same result.
>> It is certainly be good to be able to reproduce commands. However, I
>> think in most (statistical) software the default / expected behaviour is to
>> have a new automatically generated seed at each run. In R for example, if
>> you have to explicitly specify the seed using the function set.seed(). I
>> would think therefore what most users will expect a similar behaviour in
>> GRASS. It would certainly be my personal preference to have the option to
>> set the seed explicitly if you want reproducibility, but have it generated
>> automatically otherwise. But that is just a personal preference.
>>> Does the reproducibility go behind one operating system, compiler or
>> library? I don't think that the first random number is specified by the C
>> language standard. If the results would be really reproducible it would be
>> good for testing framework but I'm afraid that they are not (with my
>> limited knowledge about the topic).
>>> If you want a different result each time, set GRASS_RND_SEED to a
>>> different value each time, e.g.
>>> GRASS_RND_SEED=`date +%N` r.mapcalc "a = rand(0,100)"
>>> [%N is the nanoseconds portion of the current time; this is a GNU
>>> extension.]
>> Perhaps this can be explained like this in the manual page? A far
>> better option would be to provide this as a normal parameter so it can be
>> set from the gui interface or command line like any other variable.
>> I've heard that this is not enough on powerful computers/clusters, that
>> you have to use also PID because nanoseconds might be the same (I think I
>> rememberer that it was nanoseconds not seconds).
>>> > On a related note, it would be nice to be able to set the seed (I think
>>> > there has been such a request before, but not sure about the answer at
>>> that
>>> > time).
>>> GRASS_RND_SEED was the answer.
>> I think there should be some possibility of randomization (auto-setting
>> of seed) build-in the modules providing random(ized) results. Perhaps a
>> flag which would turn it on. It can be also an option which would behave
>> like GRASS_RND_SEED but would have one special value for auto-generating
>> the seed. (GRASS_RND_SEED if present would override this option.) With the
>> default value of the option we should ask a question what is actually the
>> expected behavior of the module giving random results.
>> Yes, that would be great. As for the default value, see my earlier
>> argument.
>> This would provide a nicer interface in Python, standard interface in
>> command line, and possibility to set it in the GUI (which means possibility
>> to set it for users which don't use command line.) Moreover, it would
>> provide all users with the way of setting the random seen in the manner
>> which we consider the best according to our knowledge.
>> Agree. The way to set the seed now may not be understood by everybody and
>> with all the work going into streamlining the GUI, this kind of fairly
>> important options should also be available through the GUI
>> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140704/5c0d2d0f/attachment-0001.html>
