[GRASS-dev] using rand(x,y) in r.mapcalc (grass7)
Sat Jul 5 15:34:59 PDT 2014
Paulo van Breugel wrote:
> Just a quick additional question, how to set this GRASS_RND_SEED from
> within a python script (I want to add the option to set the seed with a
> seed parameter in my script, as suggested in the previous email).
You can modify os.environ prior to calling it, e.g.
	import time
	import grass.script as grass
	t = int(time.time() * 1e9) % (2**31)
	os.environ['GRASS_RND_SEED'] = '%d' % t
	grass.mapcalc(...)
