[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Anna Petrášová kratochanna at gmail.com
Wed Jul 9 07:31:56 PDT 2014
On Tue, Jul 8, 2014 at 4:13 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Anna Petrášová wrote
> > On Sun, Jul 6, 2014 at 3:59 AM, Helmut Kudrnovsky <
> > hellik@
> > > wrote:
> >> "C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\script\core.py",
> li
> >> ne 58, in __init__
> >>     raise OSError
> >> OSError
> > It's because gui doesn't reflect recent changes by Martin.  I temporarily
> > fixed it in r61171 but I don't really understand current status, is it
> > still work in progress? By the way the Popen class should be changed
> > according two Glynn's suggestions to let Popen throw the error.
> > Anna
> tested with:
> System Info
> GRASS Version: 7.1.svn
> GRASS SVN Revision: 61180
> Erstellungsdatum: 2014-07-08
> Build Platform: i686-pc-mingw32
> GDAL/OGR: 1.11.0
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
> the GUI starts now, thanks.
g.gui.* modules are not found, there is no bat file created for them. Could
something similar to this be used for them as well? Otherwise everything
seems to be working.
http://trac.osgeo.org/grass/changeset/61136
Anna
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/Re-GRASS-SVN-r60679-grass-trunk-lib-python-script-tp5143645p5150047.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140709/671c090d/attachment.html>
