[GRASS-dev] problem initializing temporal gis
Luca Delucchi lucadeluge at gmail.com
Fri Jul 11 02:15:30 PDT 2014
On 28 June 2014 12:32, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hi Soeren,
> Yes, it is possible to add any amount of fields in the future. Older
> databases must then be updated to support the new fields, otherwise
> the updated framework will not work with them.
ok, so maybe it is better to collect idea and change only few times,
do you think I should open a ticket?
> However, a specific unit field that can be set by the user will
> conflict with the unit field of raster and voxel maps. IMHO the unit
> of a space time raster dataset should be derived from the units of the
> registered raster maps. Well i did not implemented this, since from my
> experience are units used very seldom for maps. So the correct
> implementation would add a units fields to raster and 3d raster map
> tables and to STRDS and STR3DS tables. The STDS SQL code must be
> updated to aggregate the unit information. But what to do if map layer
> have different units? Or if only a subset of the registered maps have
> units?
In r.support there is units field, could we use this?
Can you do some example of map layer with different units?
> So maybe the semantic type option is sufficient right now?
But it accept only min, max, sum, mean value?
> Best regards
> Soeren
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
