[GRASS-dev] [GRASS GIS] #2362: database connection for output of r.stream.snap
GRASS GIS trac at osgeo.org
Fri Jul 11 06:29:21 PDT 2014
 Reporter:  jradinger    |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Database     |     Version:  unspecified
 Keywords:               |    Platform:  All
      Cpu:  Unspecified  |
 The output of r.stream.snap in GRASS7.1 does not contain any database
 (Sqlite) table by default. So when I want to browse the attribute table I
 get the error message: "DB connection for vector map XXX not defined."
 Then I can manually define a layer (from the initial input vector).
 However I think that two layers should be created based on what is
 mentioned in the manual.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2362>
