[GRASS-dev] [GRASS GIS] #2368: Python version of r.grow does not support shrinking
trac at osgeo.org
Wed Jul 16 10:17:04 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.grow, r.grow.distance, r.buffer, r.buffer.lowmem | Platform: Unspecified
Cpu: Unspecified |
While C version of `r.grow` supports shrinking (negative distance/radius)
since r59735, the Python version of `r.grow` based on C module
`r.grow.distance` and `r.mapcalc` expression supports only growing
(positive distance/radius). Shrinking (negative buffer) is a useful
feature, so I think we should add it.
I'm not sure if negative distances can be added to `r.grow.distance`.
If not, I would say that we need to use C implementation of `r.grow`
(which might be even faster then the Python script version which calls
several modules and creates temporary maps).
If duplication of code would be an issue in case of C `r.grow` and
`r.grow.distance`, we may consider adding some functions to the library if
they are useful for more modules.
`r.buffer` and `r.buffer.lowmem` does not seem to support it neither, as
far as I know.
`v.buffer` supports negative distances ("inward buffer" / "negative
buffer").
Ticket URL: <https://trac.osgeo.org/grass/ticket/2368>
