[GRASS-dev] [GRASS GIS] #2372: GRASS 7 on windows starts with minimized CMD window
trac at osgeo.org
Fri Jul 18 06:43:47 PDT 2014
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Startup | Version: svn-releasebranch70
Keywords: wingrass | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:3 hellik]:
> Replying to [ticket:2372 marisn]:
> > This is an inverse bug of #1891
> > Steps to reproduce:
> > * Install Wingrass on a clean machine (without previous GRASS 7
install or just remove AppData/Roaming/GRASS7 folder)
> please test/see if installing winGRASS7 standalone on a fresh box
creates for you AppData/Roaming/GRASS7 folder!
> thanks
I didn't try it on 'clean' machine but I removed the GRASS7 folder and
demolocation in Documents/grassdata and everything was created and worked
fine for me.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/2372#comment:4>
