[GRASS-dev] [GRASS GIS] #2372: GRASS 7 on windows starts with minimized CMD window
trac at osgeo.org
Fri Jul 18 11:10:36 PDT 2014
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Startup | Version: svn-releasebranch70
Keywords: wingrass | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:3 hellik]:
> please test/see if installing winGRASS7 standalone on a fresh box
creates for you AppData/Roaming/GRASS7 folder!
Yes, it does. Still only for the user running the installer. I later
created a new user and there was no AppData/Roaming/GRASS7 folder with all
consequences. That explains why I observed it - in a computer lab
installations are done by the administrator but students are using their
normal user accounts. A small modification to the initial report, but it
is still valid.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2372#comment:5>
